๐Ÿ“Œ MIRACO 2 AMA: Ask Us Anything!
You ask. We answer. Simple. :handshake:
With the MIRACO 2 3D scanner coming soon to Kickstarter, we know you have questions. Whether youโ€™re curious about its specs, performance, workflows, or software, we are here to clear things up!
Just drop your questions in the comments below. Weโ€™ll also compile the most-asked questions into a dedicated FAQ.
What do you want to know about MIRACO 2? Let us know below! :backhand_index_pointing_down:
Like the Miraco, does the Miraco 2 have near and far modes?
I own a Miraco Pro. Is there a trade-in program to give back mine and get a Miraco 2 with a discount?
Hi, I own a Miraco and use it near mode for scanning faces in different expressions. What benefits will Miraco 2 provide for this, and will it be able to capture more detail in deep areas like ears, nose and mouth? Thank you.
Is the Photogrammetry Kit interchangeable (identical?) with that from the original Miraco units?
does this one come with markerless laser mode, like range3 pro do?
Yes, it does.
I have been informed directly that it is.
Interested in trade in as well
Hi @StephenC
The MIRACO 2 has more modes beside Full Field, the laser mode accuracy is 0.02mm , the full Field mode is 0.08mm , with laser you can go better results but the device is still in production and lots of things can change . Beside Full Field, you still have Hybrid , VCLR and Laser modes scanning what make it standing out plus photogrammetry what push it above MIRACO Plus capacity.
Hi @rschaeff @robobear
We are now open to all customers to do the trade-in, except for the Trackit series:
Check the link above
As other scanners must be calibrated with some special calibartion plates, does this also apply to the MIRACO 2 and is tje Calibrstion Plate included to the Set?
Is the battery swappable? If not, is it user serviceable to replace?
Yes and yes :slightly_smiling_face:
