There is no undo button in blue laser scanning mode. Every once in a while it loses track because I start on a point where there are not enough markers and then I’m already 10000 frames in. I have to redo the whole thing. Would be great if I can undo an X amount of frames.
There is the option to go in and delete key frames in RevoScan. That might be what you have to do if you are that far in to a scan.
There is not an option to delete frames for Laser scans .
If you already captured 10K of frames then the best option will be to start over , it would take forever to remove the frames if even was possible but it is not at this moment
I respectfully disagree with this statement.
I have been able to go in and delete frames from my Metrox scans
I did this on a scan where tracking got weird. But I was many frames in, so I just kept going and figured I could get rid of it later. Which worked.
Edit: I realize this was using the Full field blue light, not the crossed laser. You are correct
Hi @100
We will feed back on this suggestion. Thank you.
I let you find it out ![]()
I like to learn the hard way
The best way ![]()
