MAIRYJ | UNBOXING | POP 3 Plus
Hello everyone, here is an unboxing of the new POP 3 Plus.
The packaging is just great with a beautiful transport box covered with a kind of velvet.
So inside we have in the first part the Revopoint POP 3 Plus with a button to start the scan directly and a +/- to change the new zoom option.
So you have the rotating table, the foot/handle to come and place the scanner. As well as the traditional test bust.
in the second part we have the phone holder as well as a location for the battery and other accessories (I have the standard version and the other versions have more accessories.)
Then we have a compartment with the different cables.
A USB-A to USB-C to connect the scanner directly to your PC (USB-A - USB-C adapter also provided).
A cable to just power the turntable, it is a USB-C charging cable and therefore cannot be used to transfer data.
And finally a double USB-C to USB-A cable to power the scanner and your smartphone at the same time on the battery.
Last part we have the maker dot as well as a large mat and a round surface to put on the turntable.
There is also the new calibration board in its house. It is a new glass one which allows given the properties of the glass to increase the precision and also avoid the deformation during transport.
Thank you for reading.
Long life and prosperity, may the force of print be with you!
Nice to see all the standard kit is still supplied in the familiar format.
Do you know if the calibration board can be used with other Revopoint scanners?
It is indicated on the back compatible with POP3 Plus and Miraco in Near-mode
That’s great thank you :blush:
