What matters most to you for large-object scanning?
Trackit SR 3D Scanner is built for large-object scanning, where real-world priorities can differ from one project to another.
Depending on the job, the biggest factor might be freedom of movement, tracking stability, setup efficiency, data quality, or software processing.
For your projects, what usually ends up being the most important factor?
  1. time for place and remove marker
  2. wiring issue
Setting up hundreds of markers and then removing them can be tedious on large objects, so being able to scan large objects without them is such a big time saver. The Trackit seems like such as awesome 3D scanner.
