Unveiling Hidden Painting Changes in 3D with Trackit SR - Dfodaro
🎨 Unveiling Hidden Painting Changes in 3D!
We recently conducted a fascinating scanning test using the new Revopoint Trackit SR, and the results were nothing short of breathtaking. Our subject? A stunning panel painting featuring a beautiful female portrait in an exquisite Renaissance dress.
While paintings are traditionally viewed as strictly two-dimensional, our 3D surface scan revealed a hidden secret: a pentimento (an artist’s alteration).
  • The Discovery: A subtle transverse mark across the subject’s forehead, which is difficult to perceive with the naked eye.
  • The Mystery: This faint topological shift suggests the underlying presence of a painted veil that the artist originally drafted and later decided to cover up!
🔬 The Tech: An Addition – The Revopoint Trackit SR
This discovery was made possible by the advanced capabilities of the new scanner. It is important to note that the Trackit SR is not a replacement for the first-generation Trackit, but rather a highly specialized complementary tool designed for entirely different target use cases.
While the original Trackit excels in its broader applications, the SR is engineered specifically for intricate, close-up professional work:
  • Specialized Micro-Precision: Tailored for highly detailed, close-range scanning, it captures minute surface variations and brushstroke topography with the extreme fidelity required for art analysis.
  • Advanced Tracking Algorithms: It offers rock-solid tracking stability optimized for its specific focal range, even on “flat” or geometrically repetitive surfaces like wood panels, which are notoriously tricky to scan.
  • Targeted Resolution and Speed: Upgraded sensors are specifically tuned for macro-level data capture, delivering crisper, cleaner data with significantly lower noise, cutting down processing time for highly detailed projects.
🏛️ 3D for Cultural Heritage
This test demonstrates that 3D scanning instrumentation is an incredibly useful tool not just for statues or architecture, but for investigating substantially flat surfaces like paintings. It is paving the way for new methodologies in the protection, study, and conservation of our artistic heritage, allowing us to read the invisible history hidden just beneath the varnish.
Hi Davide,
Very nice discovery , probably head band /jewelry
BTW why you still needed markers ? Or it was just connected to your computer only ? Without Traker ?
Thanks Cath,
Yes I used the scanner connected to computer without tracker
Thank you Davide !
Did you tried it tracker less with any medium size figures?
What are the rules with artifacts and laser scanning ? Many restrictions? ( Especially referring to paintings )
Thanks Cath!
I’m working on a series of tests with different sizes and materials.
The blue laser is absolutely safe for scanning artwork.
Ps Sorry for the delay in responding but I’m no longer receiving notifications from the site.
Hi Davide ,
No. problem thank you for the info !
