The use of two cases for the Trackit makes sense given the amount gear that is included.
However it would be better if ALL of the gear associated with calibration was in one case and if the gear for basic scanning was in another case.
Currently, for general scanning where I don’t expect to need to do a calibration, I still need the bring the long case that contains the Tracker head and it’s tripod. The case that contains the scanning head also contains the calibration board and it’s tripod. I understand that the Tracker head cannot fit into the same case as the scanner head currently. But I would have preferred a slightly larger case that held the tracker head, tracker tripod, scanner, cables, and markers. In that scenaro, when I need to scan someting, I wouldn’t need to haul out both cases unless I had to do a calibration.
