Trackit SR Tracker - can it be tilted (Pitched)?
Hello,
I have needed to scan an object that is quite tall, in the past i have put the tracking unit tripod for the scanner up on a table so the scanning volume is still level.
Can I leave the tripod on the ground and “aim” the tracking unit upwards to see the scanning unit ?
(using a pan-tilt Tripod head)
I wouldn’t move it during scanning of course.
Regards,
Mike
Hi Mike,
You can put the tracking wherever you want , it don’t need to be on the tripod , you can hang it on the wall or celling or use ball head.
Thank you,
I thought as much but I wanted to be sure.
Cheers :slight_smile:
