Good morning, Yesterday I try a new test for Range…
I need one thing for studio… if is possible to chose the color of the surface…
so when we merge two scan we can see the overlapping of the two for check if is all Ok…
otherwise It’s difficolt to see immediatly if the fusion is OK…
One think like that… it could be great…
and two
in studio if is possible to save the image that we see into the screen or the video of the scan …
I don’t know of some user can show the scan rotating onto the screen…
my problem is when I made three or four scan for join toghether all the scan i became out of mind…
because I must open the first file into one directory called fuse-mesh go into another directory open a file called fuse-mesh… join after going into another directory opend fuse-mesh join…
after the thrird or four i don’t remember wich I have fuse and wich not…
for me the correct one will be
put also the name of the directory and leave the history of the scan
may be like that
with all the operation made… just for memory…
many thanks for the help…
