[Solved] Android App in Play Store
It’s been over two days but the Handy Scan app is not in the Play Store yet as per the update email.
Hi, @TheRev, could you please share a screenshot with us? Because my colleague tested and can find it is at the Top 1 when searching “Revopoint” , and at the Top 5 when searching “Handy Scan”
If you can’t find it, click this link to have a try: https://play.google.com/store/apps/details?id=com.revopoint3d.handyscan
Looks like you have it locked to a certain country/region.
Hi, @TheRev Thanks for your info. May I know which country are you located in?
USA, but I tried it VPNed from several other countries as well
same here (Switzerland). locked if looking for it with your link, otherwise it doesn’t show up at all when searching.
Hi, @ivan @TheRev, Can you try again now? I told my colleague to adjust it just now.
Hi @Revopoint3D-Cassie, still no good in Switzerland. Search gives no results and link indicates it is not available in our country :sob:
@Nebulus Sorry, maybe it also need the approve from Google side. I will keep an eye and let you know once it is available.
same problem from Germany. I cannot use the download either. It just gives me the message “file not found”.
Hi,
Just tested the download link from here, works perfectly.
In case of, here are the direct link:
https://revopoint3d.com/wp-content/uploads/download/HandyScan1.5.0_20210430_release.zip
thank you, the Problem was my APK-Installer which pointed to a wrong version.
With pleasure :slight_smile: Glad to have helped you
Good now in Switzerland :grinning:
Just downloaded Form Play Store in Germany.:+1:
Can confirm that I can now download from Play Store in USA.
Also just got my shipping notification. I received it last week.
Hello All,
today I have open the app with my LGv30 from play store. Nice
Case#2 closed for me.
Oscar,
thanks for your report, so, I think problems solved, I will close the topic :slight_smile:
I have the same problem. The Play store does not allow me to see the HS app. It says I have no compatible devices. However, I am running the Android apk on my phone without issue.
I have the version that was made available on the forum.
Hi @Bman
May I know what phone are you using? Can you share the spec of it?
Btw, which version of Handy Scan are you using now?
Cassie
