Small object help
Hi,
(Miraco Plus)
I’ve been trying to scan a small stone and also a little broken piece off of a toy (to 3d print a replacement).
I’ve used the turntable set to it’s slowest speed, set it inside a lightbox to ensure good even lighting and have attempted with reflective dots on the turntable & with other feature-rich objects on the table at the same time but I’m constantly getting loss of tracking and terrible results.
Usual settings: Near scan mode - High Accuracy - Feature Alignment - General Object Type - Enhanced tracking ON (have tried off too) - mostly Excellent range.
Can anyone give me any tips as to what I might be doing wrong or what else I can do to get a better result? So far my best outcome has been placing the stone on my desk (with nothing else around it) and scanning freehand, but surely this is exactly the type of thing the turntable setup is intended for?
Thanks,
Joe
Hi Joe,
If your objects are very small try to add some other little objects to your turntable fur stabilization , structure light technology relays heavily on features for tracking , if you want to scan just the little stone use a marker mode with markers on the turntable , it will works even better.
You can also use single shots mode to get better accuracy.
Let me know if this worked for you .
Thanks for your response.
Marker mode worked infinitely better - I’d sort of forgotten that it existed within the ‘Point Clouds’ area!
For larger objects - at what point would you stop using Point Clouds > Marker and move to Global Marker?
Hi @JoeHorse
Global markers are always better regarding the accuracy and precision regardless of the scanned objects.
Global markers are faster and provide better scanning results.
You have a Miraco Plus so the zoom is optical and should help with very small objects.
You also have the photogrammetry option for very large objects, sort of like global marker mode on steroids.
