Scan orientation Issues?
Just received my POP 2 scanner. I began testing it’s capabilities and found that while scanning, the scan will loose it’s orientation. The software doesn’t indicate lost tracking, but I end up with this after attempting to Fuse;
Has anyone had this problem? It has happened on static and live models alike. I have attempted to scan using my iPhone and Macbook with the same results. I’ve also tried to use marker mode with the supplied tabs and had no success.
