RevoPoint Trackit SR Not scanning cause of 2deg?
Seems like my new scanner wont do anything if its too hot by 2deg outside.. this is normal or is it going to not work at all if its even slightly hot?
Hi @alexn9200
For the best results the outdoor ambient temperature need to be at least in the ±2 range , you should not Calibrate it indoor and then use outdoors where us hotter, the laser elements are very sensitive and will expand.
Calibrate it in the temperarure you going to use it. Even only the scanner itself without the rest may help archiving better results .
