With my computer the scanner software will not function. I am running an AMD Thread Ripper Pro 4ghz 16 Core processor with an RTX4080 NVIDIA Graphics card and Windows 10 Pro installed. Program on execution prompts to run as administrator but doesn’t open. Program will not work in compatibility mode for Windows Windows 98/Vista/ 8/ or 10
Did you got the latest version of Revo Scan v3.1.7 ? If not you can download it from the Starting Point/ Download section in the forum .
Also Revo Scan support only Win 8 and above .
You may try to right click on the icon and check what GPU it uses as I am suspecting it is running on other GPU than your Nvidia card , change the settings and try to open again .
Revo Scan requires OpenGL 4.0+ to run
And in most cases it will not open if the wrong GPU is selected.
