Revopoint 3d pop
After scan using revopont pop 3d scanner will it can be save as stl right away? Is it difficult to edit the scanned image and save as stl file
Please help
The default file format is PLY, so you have to specify the STL format each time you save the file.
Or you can do what I do and load the PLY files into MeshLab and export them as STL (it’s easier and faster because I do that on my computer instead of on my laptop).
