Revo Scan App makes objects with no UVs
I’m a 3D artist
I just bought a POP3 scanner and want to only use my phone as I do not want to carry a laptop.
The viewport texture looks nice. But textured mode does give me a texture but the OBJ or FBX contains zero UV layouts. Which is realllly strange. I tried making a new OBJs like 5 times already.
I’m kinda of forced to use laptop JUST for the texture. If both doesn’t work I might have to return it :confused: and look for other 3D scanners.
Hi @benwei1314
You need to export textured model and not just OBJ , create textures at the end of the process then choice to export Textured Model .
Just remember that processing scans on a phone will deliver lower quality results compared to processing in a dedicated laptop .
I did. I selected all the check boxes. It created a texture WITHOUT UV islands on the model. Which is really strange. Maybe the model was corrupted or overwritten?
Have you tried using the app to quickly do a test texture scan yourself?? I really need a scanned model with texture as a base for 3d modeling.
Oh I’m the guy from discord if you can message and help me there that would be great :slight_smile:
Hi @benwei1314
I will test it today and let you know if it is software issue or not .
You are using the latest Revo Scan 6 right ?
Yes Revo Scan V6.0.2
Yeah i checked all of the boxes and it spits out many objs and fbx with textures. Just not models with UVs.
Maybe it’s the way of how I transfer the files? Which erased the UVs and it corrupts it???
My iphone workflow is. Export the obj with texture onto my File app> I use micro USB into USB adaptor to pull the file from file app directly to the USB. So I dont have to email it to me which takes ages to send and download.
I am checking with the team on it , I don’t use iPhone so can’t test it out.
BTW when exporting OBJ , do you have also MTL files ? You need OBJ, MTL, Textures
Hi @benwei1314
Here are some recommendations for checking:
1、On your iPhone’s Revo Scan app, ensure that you select “OBJ + Texture” or “Textured OBJ” during export instead of “Plain OBJ” or “Mesh-only OBJ.”
2、After exporting to the “Files” app, make sure you copy not just the .obj file but also the .mtl file and texture images from the same export directory to your USB drive.
3、Do not rename these files or change their relative paths, as this may cause textures to fail to load correctly.
4、Open the .obj file on your computer with a text editor and search for “vt” to confirm if UV coordinates are present.
5、Finally, use Blender, MeshLab, or other 3D software to import the OBJ file and check if the textures display correctly.
ok thank you for looking into it. Id try again
No problem @benwei1314
If anything let me know , the team tested the iPhone and the OBJ , MTL and textures was available, I think you forgot to copy the MTL from the app folder .
