Revo Scan 4.1: Scan problem with Dual Axis Turntable scanning two sides of an object
Hi,
how should I proceed with the turntable if I have scanned an object and also want to scan the bottom side? The pause button, which I would need for reorienting the object, cannot be activated.
Thanks for your answers in advance!
Regards Frank
You can’t scan the bottom in the same scanning session using Dual Axis turntable , you will need to run another session and later merge it in Revo Studio .
As the name says , Dual Axis allows you to scan 2 positions at once so you have only 2 scans to merge later in place of 3 .
Of course it would be better if we could just pause the scan and change position and run the sequence again , but at this moment it don’t works this way , hopefully it will change in the future .
Yes you can if you are fast. Program a 4 turns scan and move objet on the last one. Pause button is not yet available, waiting for an update…
But i made it ! Scanner Revopoint Mini - YouTube
You can’t pause it , and that was my answer to the question .
You lucky you got alignment, with more complex object it will be not so easy .
Anyway , if you try tricks like that , start scanning when the model is on the side first , then at the end let it stand straight, you will get quicker alignment of the frames and lower chance of losing tracking .
Also you distance was at 20 cm , remember you losing half of the sharpness , set you distance at 10 cm for best resolution , especially for very small objects . Distance with MINI is critical for the quality since the range is very short
I scan with MINI and dual Axis for almost 4 months now , but my own Dual Axis can be paused since it is controlled by remote control.
