Revo Scan 4.1.1.20220930b crashes during a scan
My Revo Scan persistently crashes during a scan. Here is the video: https://www.youtube.com/watch?v=7YWQd2WeMNQ
The application just terminates silently in the middle of scan without any prompts or error messages. Log files attached. Log.txt, Sdk.log
Computer parameters:
OS Name	Microsoft Windows 10 Pro
Version	10.0.19043 Build 19043
Other OS Description 	Not Available
OS Manufacturer	Microsoft Corporation
System Manufacturer	Micro-Star International Co., Ltd.
System Model	MS-7D25
System Type	x64-based PC
System SKU	Default string
Processor	12th Gen Intel(R) Core(TM) i7-12700K, 3610 Mhz, 12 Core(s), 20 Logical Processor(s)
BIOS Version/Date	American Megatrends International, LLC. 1.10, 12/13/2021
SMBIOS Version	3.4
Embedded Controller Version	255.255
BIOS Mode	UEFI
BaseBoard Manufacturer	Micro-Star International Co., Ltd.
BaseBoard Product	PRO Z690-A WIFI DDR4(MS-7D25)
BaseBoard Version	1.0
Platform Role	Desktop
Secure Boot State	Off
Windows Directory	C:\WINDOWS
System Directory	C:\WINDOWS\system32
Boot Device	\Device\HarddiskVolume4
Hardware Abstraction Layer	Version = "10.0.19041.2251"
Time Zone	Mountain Standard Time
Installed Physical Memory (RAM)	64.0 GB
Total Physical Memory	63.8 GB
Available Physical Memory	38.2 GB
Total Virtual Memory	132 GB
Available Virtual Memory	98.9 GB
Page File Space	68.0 GB
Page File	C:\pagefile.sys
Kernel DMA Protection	Off
Virtualization-based security	Not enabled
Device Encryption Support	Elevation Required to View
Hyper-V - VM Monitor Mode Extensions	Yes
Hyper-V - Second Level Address Translation Extensions	Yes
Hyper-V - Virtualization Enabled in Firmware	Yes
Hyper-V - Data Execution Protection	Yes
GPU	RTX 3080 Ti
GPU Memory	12 GB
Description	Disk drive
Manufacturer	(Standard disk drives)
Model	Samsung SSD 980 PRO 2TB
Bytes/Sector	512
Media Loaded	Yes
Media Type	Fixed hard disk
Partitions	3
SCSI Bus	0
SCSI Logical Unit	0
SCSI Port	1
SCSI Target ID	0
Sectors/Track	63
Size	1.82 TB (2,000,396,321,280 bytes)
Total Cylinders	243,201
Total Sectors	3,907,024,065
Total Tracks	62,016,255
Transfer Rate	8 GB/s
Tracks/Cylinder	255
Partition	Disk #1, Partition #0
Partition Size	100.00 MB (104,857,600 bytes)
Partition Starting Offset	135,266,304 bytes
Partition	Disk #1, Partition #1
Partition Size	1.82 TB (1,999,500,214,272 bytes)
Partition Starting Offset	240,123,904 bytes
Partition	Disk #1, Partition #2
Partition Size	628.00 MB (658,505,728 bytes)
Partition Starting Offset	1,999,740,338,176 bytes
Update: Tried to turn Hardware Acceleration off, nothing changed - program still crashes.
Hi @arifg ,
Sorry so much for this issue. We will discuss it and let you know asap.
Cassie
@Revopoint3D-Cassie , I found already the issue of crashing, it is the last RTX graphic driver that is responsible in crashing of Revo Scan 4.1.1
The Dev Team should look into it ASAP and provide stable update or nobody would use Revo Scan with their RTX graphic cards that are up to date with their drivers.
The user with the problem need to roll back the last graphic card driver to be able to use Revo Scan .
Process Monitor (Procmon) log
Dear @PopUpTheVolume ,
Thank you. I had transferred this post to our product team. With your suggestion, I think they can find the reason of this problem soon. :smiling_face_with_three_hearts:
Cassie
Hi @arifg ,
Got it, thank you.
Cassie
Video driver as a culprit seems plausible. After installing the latest NVIDIA STUDIO driver instead of the NVIDIA Game Ready driver, the issue apparently has been gone; scan finishes fine.
Hi @arifg ,
Thank you for your update information.
We will try our best to solve this problem asap.
Cassie
