Good day, i am having difficulty to read text in app on laptop screen which is 4k rez. Is it my local problem or it is known bug? I would suggest option to make text size slider, which could help to size correctly for software gui.
No it is not your local problem , the software is made for use with HD resolution
I will move your thread to Suggestions
Thank you for clarification and fast response.
Trt the overides.
Right click the app icon
Properties
Compatibility
Change high DPI settings
High dpi scaling override.
Click the check box and then drop down to
System.
If system does not work try system enhanced
You can quickly adjust your Windows screen size to a lower resolution and set it back just as quickly when you are done scanning. Revo Scan is quite legible on my 32" QHD monitor (2560x1440).
Thank you all for replay and suggestions. Yes downscale or compatibility dpi helps. This topic can be closed or left for others to check if they encounter this issue. For me also good news that developer knows this and i hope/maybe/possible is working on this feature in future releases. As it is not critical, it am not hopping for fast update on this question. Once again thank you all for suggestions.
