# RANGE scanner car scan
**URL:** <https://forum.revopoint3d.com/t/range-scanner-car-scan/19344>\
**Category:** RANGE Series\
**Created:** [February 7, 2023, 12:02pm UTC](https://forum.revopoint3d.com/t/range-scanner-car-scan/19344 "2023-02-07T12:02:35Z")\
**Posts on this page:** 1\
**Showing post:** 21
<div class="post-metadata">
**Author:** ![ivan](https://yyz1.discourse-cdn.com/flex029/user_avatar/forum.revopoint3d.com/ivan/32/16571_2.png) [@ivan](https://forum.revopoint3d.com/u/ivan)\
**Post date:** [February 9, 2023, 2:10pm UTC](https://forum.revopoint3d.com/t/range-scanner-car-scan/19344/21 "2023-02-09T14:10:29Z")
</div>
No overkill at all. Especially regarding RAM! The more, the better! I wouldn’t go below 32gb and was happy after upgrading to 64gb.
Also check
> [@How much RAM for the MINI?](https://forum.revopoint3d.com/t/how-much-ram-for-the-mini/17088):
> Hi @Revopoint3d-Selina @PUTV or anyone who might know. I will be receiving my MINI scanner soon and had a question about RAM for the Revoscan and Revostudio PC software. What is the minimum amount of RAM recommended for using the MINI on the PC? Is it correct that a higher amount of RAM would make things process faster (fusing & meshing)? Or does the software set a limit to how much RAM it uses? I understand CPU, and the SSD play a part also with processing time. My laptop currently has 8g…
_[View the full topic](https://forum.revopoint3d.com/t/range-scanner-car-scan/19344)._
