Hi Wilso31. I am on Catalina & had the same problem. The version Cassie referred to above solved the issue though it requires I sign in as administrator each time I run the software. Hope that helps.
Yes i tried both. Do i still have to conect through the phone to use it. Or am i doing something wrong are there instructions that are clear on setting this up
No, Handyscan runs on your Mac, no phone needed - use the USB cables provided to connect POP to your computer. No instructions for the software yet that I know of but it’s possible there is a link to them somewhere in the forum provided long ago before Revoscan got Handyscan working for OSX. The version that works on Catalina only just came out a few weeks ago. I regret I’ve been too busy since to do anything other than a cursory test of the software.
I have re installed the handy scan program beta version 3 to my mac running Catalina and clicked on about. And i put a user name and password in and get press confirm .
Please go "About this mac → Sysem Report… → Hardware - USB " and check if there is “ZXProduct”. If no, please unplug and replug to see if it will appear. If still no, could you double confirm that USB port is USB3.0?
Btw, do you have another Mac laptop can be used to test?
I had a problem connecting to my windows computer sent device back and got another one and it did the same thing, Do not screw the cord all the way in the back of scanner, that seem to fix my problem.
