Power Bank I cannot charge the battery, what should I do?
Did you tried to charge with different power sources? If nothing works contact the customer service for replacement.
Hi,
Is it plugged correctly?
It needs plugged in the Input port to charge.
You can use your phone’s charger if the charging port of your mobile phone is type C.
In the normal charging state, you will see the indicator light flashing; if it is unable to charge, contact customer@revopoint3d.com, and we will resend one.
