Pop 4 not working any more in marker mode
Hello, I have problems with the marker mode since I updated Revopoint to 6.4.1 When I connect the scanner and attempt to scan an object in marker mode , the lasers are very dim and there is no preview even though its enabled, and it does not show the distance of the scanner to the subject. It will not scan when I press the scan button. I have scanned the same object with the same markers in place about a week ago before the update and it worked ok. I am connected with usb to a macbook pro. Since the only change I made is the software update I tend to think it caused it, but not sure. Thanks for your help.
Update: updated Revoscan to 6.4.2 same problem
any time you update software its best to go through and do a calibration in that software. 99% of the time that will fix your issues.
Hi @PatDz
Please recalibrate the scanner , if you still have issues after that , please contact customer@revopoint3d.com for technical assistance, but I am sure the calibration will fix that .
Since both replies point to recalibration, that is worth trying first, especially because the lasers being dim and the missing distance readout sound like a state the scanner falls into rather than a marker-recognition problem. PatDz, did the update reset or lose a calibration profile, or did you do a fresh one under 6.4.2? If recalibration doesn’t restore the preview, noting whether it persists when you switch back to feature mode on the same USB connection would help narrow down whether it’s firmware-side or the Mac software.
Marker mode failing on the POP 4 could come down to a few practical things before assuming hardware trouble. Worth checking that the marker tracking setting hasn’t shifted after a firmware or software update, and that the markers are clean, matte, and lit evenly without glare. If the scan worked previously and nothing changed, try resetting the scanner defaults and re-running a short test scan. Does it fail to detect markers at all, or only lose tracking mid-scan? That distinction would help narrow whether it’s calibration or environment.
Hi @farleymerbaum23
Marker failing always indicate calibration issue , usually can happen after firmware updates date , but not often after software update , however I always recalibrate after firmware or software update especially when algorithms was changed.
Hi all thanks for your help. I did re calibrate and now it works fine, lesson learned
Hi @PatDz
That’s good to hear !
Glad the recalibration sorted it out. Worth noting that these calibration quirks tend to show up right after an update changes how the marker data gets interpreted, so keeping an eye on release notes for algorithm changes could save you some head-scratching next time. Did the calibration routine take longer than usual, or was it the standard procedure? Either way, good reminder that the simple fix is often the right one before assuming hardware trouble.
