I think I solved the problem of poor quality full field scanning - by finding a different problem.
I already calibrated my Pop4 three times, it goes like this:
- I launch the calibration program
- scan the board
- perform Acuuracy check
- FAIL accuracy check - instructed to do calibration for my scanner
- I go through the entire process of calibrating the scanner
- after calibration the scanner PASSES the accuracy check
- I save the calibration data
- Revoscan reboots, Pop4 reboots
- I launch the calibration process again
- scan the board
- perform Accuracy check
- FAIL accuracy check, instructed to do calibration again
Either the accuracy check process is not working properly, or the new calibration data does not get stored on the Pop4 ![]()
Can anyone confirm if his Pop4 passes the accuracy check after the calibration?
