Pop 2 Marks Mode Feature Request
It is possible to use marks mode as professional 3D Scanner on the market:
  1. scan the marks as rough structure
  2. scan the details of object by tracking the structure that scanned and stored earlier.
Hi @PandaBall ,
Sorry, I’m a little confused. Do you mean that we should add the Marker mode?
There is the Marker Mode on the Revo Scan, and we provided 200pcs markers inside the box.
Cassie
No Cassie , that is a different system that POP is using . POP is using markers mode for visual tracking only in real time . Expensive 3D scanners use it to pre scan and measure the object before the final scan . It is very advanced process.
Wow, fantastic!It’s a great idea!
Hi @PopUpTheVolume
Thank you. Got it. I will discuss with our developer team about this.
Cassie
@Revopoint3D-Cassie the device is already capable of doing it , but the software is not , and definitely not on Smartphone as that is a lot of data to be processed , if your programmers ever manage to add this feature in the future , it would make POP or future scan devices on another level , but the programming would be costly . Not over night solution.
Hi Cassie
This link shows the concept very well, he quickly captured the markers on the bike frame and saved it than scanned the surface with the saved marker grid as a guide, this would be very useful!
Hope you don’t mind me sharing the video link
Hi @PopUpTheVolume ,
Noted with thanks. I will let you know if we have any plan about it.
Cassie
Hi @Johnathan ,
Thank you so much for sharing this video! It is helpful.
Cassie
