No export button revoscan for iPad
I can’t see how to export my scan, there’s no button in the iOS app like I see in the tutorials, any help?
You will not be able to export until you Stop, Complete and Fuse into a Point Cloud (you can also Mesh in Revo Scan, or wait until you import the file into Revo Studio).
Once you have the option, the default export for a fused Point Cloud is PLY (OBJ is also available). If you Mesh in Revo Scan, you will be able to export in PLY, OBJ or STL.
The export option is in the Model List ( Project List) mobile applications don’t have export buttons on the main screen, after you finished fusing/ meshing , go to the project list and find your last scan session and export the mesh , the fused point cloud should be exported automatic together with the obj mesh as well .
Hi @JeffLindstrom @PUTV
Thanks for the advice, I went through , scanned the statue, stopped/completed the scan, fused and completed the mesh (it showed “mesh completed) including filling the holes.
From there still no export option, I went back into the project list and nothing was in there, and the scan disappeared
I only found one way to get out of the scanning /fusing screen, by pressing the < (back) button in the top left corner of the screen to return to the main/project screen and there on could find no saved project
Any further advice?
It can’t get lost or you will not have it on the screen , some how the Model List got hidden in your app . You should have it on your front face App where you have also settings etc…
Let me ask @Revopoint3d-Selina for advice on it , maybe there is a bug in the iOS app .
Hi
Please click this icon.
So that you can go back and find the model list. Then, you will the all your scanned files in the model list.
iPad Air 4
iOS 15.6
Revoscan- latest
Thanks
I did, there were no models in the list
Ok @Revopoint3d-Selina that is still the same bug that was not resolved yet by the R&D … I was hoping it was addressed already but seems it is not .
The project list not showing the models and that is not the first case already .
@Adhimutto the models should be under the data folder of Revo Scan on your device , check it out in main time until the bug is fixed .
I will ask the team to fix the bug ASAP.
@PUTV
There doesn’t seem to be any revopoint folder on my device, I wonder if this has anything to do with the bug on the app??
You need to have the folder , I don’t know exactly the location on your device but it must be there or you would be not able to mesh your fused point cloud . It is in the system . The app is storing all your fused point cloud there regardless if you can see it in the model list or not .
The App bug do not link it to the folder , but it is there for sure .
Hi @Revopoint3d-Selina , do you have any idea when the app bug will be fixed? I have a few projects to scan….
If it’s going to take a while, could you ask someone on the iOS app team; where I can find the folder that has the scans already done? I can’t see any Revo scan folder on my iPad
Thanks
Hi @Adhimutto Revopoint is on holidays until the end of the week so they probably back on Monday .
There are no fixes yet for your issue and will be addressed after they are back .
And regarding the folder I think it is called handyxxx something on your iPad and it is in the system under user data .
Please search your iPad for " fuse.ply" or “fuse_mesh.obj” once you find the folder with the files you will find all your scanning sessions and the main folder .
I saw once the exact path on iPad in the forum here but it was some time ago .
Hi
I am sorry for the inconvenience. I asked the team in charge. I will reply to you soon.
