NEED V4.3.2 OF REVOSCAN OR OLDER version FOR POP1
HI t MY POP1 HAS LOW FRAME RATE ON REVOSCAN 5 BUT ON THE OLDER VERSION OF SOFTWARE IT WAS OK
SO I NEED OLDER VERSION
AND IF THAT NOT POSSIBLE IS ANDROID NEW VERSION OK FOR POP1 ( NO LOW FPS )???
Hi @ali
POP1 was a very slow scanner to begin with , I don’t know how many frames you got with RS 5 per second but don’t expect much.
Write to customer@revopoint3d.com and ask for early copy , they may help you out.
Its 3 fps in all mode and in android is also like that
But on v4.3 and lower of revoscan it was about 10 frame
Hi @ali
Yes it was 10 fps on computer and 8 fps on Android , please contact customer@revopoint3d.com and ask for the older software version.
Hi!
I don’t know if this version ( HandyScan3.0.6) is good enough for you but you can try. I uploaded it here:
I will upload any version up to 4.3.2 if I can find it, too.
cheers
I found 4.0.0 , too.
Both versions available for download for one week.
That’s great Ivan , thank you for sharing !
Thanks so much ivan
V3. Works great :+1:
V4 had bug
