That may explain why you can’t get as good details , since after my update I can’t either so things are clear , we need new firmware update fixing this issue and the dev team is on it already investigating .
I will let you know when I get news .
OK so what I found out regarding the issues with my MINI after installing the latest firmware.
It reset my calibration settings and messed it up
after re-calibrating my device it works fine again
so If you ever get issues after firmware update please make calibration test first , I usually recalibrate it when it reach 0.09000 since my MINI usually is after calibration around 0.0200-0.0370
Something to remember about , it may not be always the case, but it is worthy to make Calibration tests after each firmware update to make sure your Calibration is in a proper state.
To be honest I did not saw any . Maybe it was only connectivity update so if you not experienced anything bad hold your horses with the firmware update .
What you mean 0.487
The test was before calibration 0.487 or after ?
If after then is us very bad and you need a new calibration .
Can you please show your scans without color , or scan it without color ?
Your scan is too soft on the edges , can you just scan it at 10 cm distance from the scan and scan just one 360 rotation with the maximum speed of the turntable ?
If possible could you share with me the mesh and fuse point do I could help you more .
Your scan is not optimal and I want to find out why and what is going wrong .
I know you scanning bottom and top at the same time in one session what is not recommend when scanning do find details , if you want max accuracy you can’t do that , you need to scan 2 angles separately and merge the fused point cloud together after .
