Help saving unmeshed point cloud
When I try to share an unmeshed point scan, I get an error saying “no data file!”. There’s no way to fuse a mesh after you’ve declined to fuse a mess after the scanning process and the only option that works is to delete the project file.
How can I get that data off my Pixel 6 to fuse in an external program?
You can’t , you can’t share frames, you need to fuse the frames into point cloud then you can share the point cloud .
Not need to mesh it if you don’t want, but you need to fuse the points from the captured frames directly after scanning , that is how it works .
There are no project files saved to your phone that have all the data , it is all loaded into your RAM , once you fuse point cloud , the data is removed and if you do not fuse, it is removed too .
The folder Is empty you can remove it, there is no data no more .
Thank you. I think I understand.
I think you misunderstood that fusing is meshing , meshing is a different option after fusing .
Always fuse your scan first , then you get a point cloud that you can export / share
You can mesh it later in Revo Studio on your computer .
Thank you for the clarification. I thought that fusing was making a mesh, but it’s making a point cloud that can be exported.
  • Alex O.
That’s correct Alex :+1::wink:
