[Guide] How to use Mark Mode to scan objects?
As you know, the objects with geometrical features and complex shapes, you can scan them with “Feature” mode directly;
However, when scanning objects like cups or boxes with simple geometric features, please scan with markers. Then select “Marker” mode.
Scanning Methods
There are three scanning methods :
  1. Stick markers on the surface of an object;
    Here follows a car scanning video: Revopoint POP Object Scan 7, Scan a car - YouTube
2.Place an object on the desk with markers;
3.Place an object on a turntable with markers;
In 2 &3 methods, the relative position of an object and a turntable/desk cannot change.
To ensure that, you shall export several models of an object to merge a complete 3D model.
For example:
a. Raise the tripod to make the POP and markers being approximately 45°- 60°;
b. Adjust an “Excellent” distance;
c. Select “Marker” mode;
d. Adjust “Exposure” and “Gain” values;
e. Scanning;
The First Model Scanning
  1. Start to scan;
  2. Make sure Markers valid (more than five red dots in the center window);
  3. Complete scanning;
  4. Export 1st model;
  5. Name the model Cup 1, save in ply., obj., or stl.;
The Second Model Scanning
  1. Turn the cup over;
  2. Start to scan;
  3. Scan 2nd circle;
  4. Export the 2nd model in ply., obj., or stl.;
f. Merge;
  1. Models imported in Handy Studio ;
  2. Mark on models;
  3. Merge;
Note:
  1. Scanning repeatedly can’t help the accuracy, and only a closer distance can improve it.
  2. If necessary, you can scan more than 2 models to merge them into a complete one.
Thanks for this tutorial, it’s just what’s needed.
Perhaps some others for general scanning as well would be good?
Where do we download Handy Studio?
I have Handy Scan but not studio…
Handy Studio is installed to this place with HandyScan.
“C:\Program Files\HandyScan\HandyScan\mtp\ModelProcessTool.exe”
Probably, your can see app short cut on your windows desktop.
What adjustments to exposure and gain do I make? What is good exposure, what is bad? What is good gain, what is bad?
