GM6T40 and 1.0 Ecoboost scanning to make adaptor plate
I recently purchased a POP 4 scanner to go with my Miraco, which I have owned for 15 months, to make an adaptor plate to fit a GM6T40 to a 1.0 EcoBoost.
Overall, I have been impressed with the speed and quality of the scans I can get with this kit.
Helpful tips: cleaning off items before scanning and using scanning spray or similar really helps. When printing, to check your work, think about the shrink rate of the material used.
Last thing: running a calibration after a software update is very important. I was lazy, skipped that step, and ended up restarting.
The GM6T40-to-1.0 EcoBoost adapter idea is interesting, but the hard part is usually the datum side rather than the scan itself. On a used transaxle case, the bellhousing face and locating dowel bores are what set your offsets, so I’d treat those as the reference geometry and keep the printed or machined plate’s register generous enough to allow a small shim. What mirroring or surface-reconstruction steps are you planning for the cut faces, since those tend to read poorly on a hand scanner?
The GM6T40 bellhousing face is a tricky one to capture cleanly, especially around the starter pocket where the surface steps back. If you’re using a scanner for the adaptor plate, consider blocking out the bolt-hole bosses so the mesh doesn’t collapse into them. On the 1.0 Ecoboost side, the crank sensor reluctor area matters more than most people expect. Are you planning to scan both faces and align them in software, or work off one reference surface? Curious how you’re handling the offset tolerance between the two patterns.
Scanning a bellhousing and block face for an adaptor plate is mostly about datum control, so I’d focus on how you’re referencing the two surfaces rather than the capture itself. Did you establish a common coordinate system before comparing the GM6T40 pattern to the 1.0 Ecoboost block, or are you aligning them afterward? The bolt-hole centering matters more than overall surface fidelity for a plate that has to locate the transmission concentrically. Curious what tolerance you’re targeting and whether you plan to verify with a test fit before cutting the final part.
