Just bought a new Miraco and trying to transfer files or projects to my WIN 11 PC using either WIFI or Cable and getting the same message about disk space or file watever right after transfer progress bar is done. I have a lot of available space on my HD. 64gb ram too. What’s wrong can someone please help?
Hi, please make sure you are using Revo Scan 6 on your Windows PC.
To resolve issues with the Miraco and RS6, please try the following steps to activate your Miraco:
Connect the Miraco to your computer using the USB cable.
Select “PC Mode” on the Miraco.
Ensure your computer is connected to the internet.
Open the Revo Scan 6 (v6.3.1) software. An activation window should appear automatically; click “Online Activation” to activate your scanner.
Note: Sometimes the system activates automatically; if you can access the scanning interface and perform a scan while in PC Mode, the device is already activated.
Once activation is complete, you can use the scanner normally on your computer. Alternatively, you can disconnect and reconnect the cable, then select “File Transfer Mode” to transfer files.
Hi @nicolas1
If the above don’t help , just connect your Miraco to your computer using the cable and copy and paste the project to your computer , don’t open them directly from MIRACO. That is one of the fastest way .
