so far so good. I’m currently making a bigger turntable the one that shipped with my POP2 wabbles a lot and is causing my scanner to “Loss track” so I’m making a new one, I also need to change out my GPU as the scanning process uses 98% of my CPU while scanning and although my CPU it water-cooled it still hurts to see lol.
Hi Cassie,
The calibration program does not start up, running as administrator does not help. Or re-installing or restarting the pc. Lenovo thinkpad tablet.
Windows 10 pro 64bit
What should I change in my Firewall settings?
I tried to run calibration with AVG off, that did not help.
Firewall setting says: Microsoft defender firewall is inactive, since I use other providers (?)
Another question: When the pop scanner is calibrated on one device, will the same calibration be accurate when using another computer?
Usually no need to set the firewall. Just a user told me that he could use the Revo Calibration after he turns off the firewall. Now my colleague is confirming the problem reason.
Yes, after you calibrate the scanner and write the result, the device has the exact calibration when using another computer. (Btw, you mean POP 2, right? Now the calibration software is not available for POP.)
Thank you Cassie.
Yes Pop2, received it yesterday.
I will try to calibrate using another computer.
Will let you know the results in a few days. Out of office now.
Erik
hello, I’m blocked when I do the calibration at level 15/23. impossible to have the adequate distance despite the frame and the green line. Does anyone have a solution?
My pop2 is new but when I scan the statue (cesar…?) the mouth isn’t drawn as well.
Thank you for your help
Nicolas
May I know if you tried one more time? I wonder if it is always be very difficult at 15/23. (I don’t meet this issue when testing it).
For the mouse of Agrippa sample, please make sure that the distance is Excellent so that POP 2 can catch more details. The mode should be High- Accuracy. For this white sculpture, pls choose “No color”. Firstly, make the sculpture stand on the turntable, and scan for one circle, then, put it down on the turntable, and scan another circle.
Every time I try to open the calibration program I get a flash of the program on screen and then nothing happens. I have tried re installing, running as administrator compatibility mode, nothing works Please help as my scanner needs to be calibrated as it frequently loses it’s place and start’s
into a never ending spin. Thanks
You should be able to run the software, I hope the staff can help you with that but …
Calibration has nothing to do with your problem , and will not fix your problems .
The problem you experiencing is because :
Not enough features on your object
Too much Anbient or direct Light
Wrong mode for wrong object
You overscan the surfaces too many times the first time
The surface is too smooth - use marker mode with markers, or the turntable top plate and make sure the markers showing up in your Depth camera preview .
Make sure the object is visible in the preview as much as possible , first scan at 360 rotation-300 frames and fusion … it will give you a good base to finish the rest of the scan , continue scanning just the 360 rotation and fuse it each time .Do not overlap the scanned area , bad for the mesh and bad fir the textures. Scanning the object too many times over and over will not improve the quality.
@PCB_segmen are you sure you don’t purchased POP 1 ? all POP2 was shipped in the middle of March with the calibration plates included . There was not early shipping without calibration plates.
So question Cassie, does the original POP version have a method to calibrate it? Downloaded the Revo Calibration program and it recognizes the camera but when I go to connect the camera it freezes up and doesn’t connect. Any suggestions? Sounds like I am going to have to look for a POP 2.
Thank You, Nick
Hi @PUTV, I follow the video instruction, and got my best result is 0.15. How could you get the 0.05 accuracy, does the lighting room affect the calibration process?
Thank you in advance
@Revopoint-Cassie
Hello
What should I do if the calibration program does not run?
I use desktop.
When you run a program, nothing happens.
It’s the same if run it with administrator privileges.
