Calibration is calibrating the scanner to ensure the most accurate data scanning and alignment. In other words, it makes the scanner more accurate so that you get the BEST scan results.
2. Why do we need to calibrate our scanners?
Usually, the camera has been accurately calibrated before shipping from the factory.
However, the camera’s accuracy may be affected for the following reasons:
After a long time using.
Long-distance transportation.
Changes in the environment.
External forces & violent collisions.
Under such conditions, the camera’s default settings will deviate from the optimum.
3. What will happen if you don’t calibratethe scanner?
It will in poor scanner accuracy; the results looks terrible and the model’s dimensions are no longer reliable.
This means you need to calibrate your scanner!
Until now, only professional-level 3D scanners had calibration capabilities. With a consumer-level price, the POP 2 has this function too.
Hi @Revopoint-Cassie Wonder if the calibration board is included in the premium pledge? Or where can we get it?
Best regards and thanks for tutorial on calibration
Per
May I know if you tried to run this software as an administrator? We met a user can’t use it at first, then finally solve the problem by running it as an administrator.
Well I tried again , I got better ., and also better results in scanning and little less noisy , somehow the Depth map sensor does not cut the image in half anymore and the scanning area seems in the center with the RGB and in sinc . I still have the best results with 20 cm distance of scanned objects and most sharper textures , anything closer get blurred and more fuzzy . 20 cm distance working also great with tracking .
