Dual Axis Turntable control question
Good day,
I recently got a new Dual Axis Turntable, I think I got both versions (but the old version died after a very short time, got a new replacement without any hassle, thanks Revopoint), but I just can’t seem to figure out if this thing can be automatically controlled by Revoscan 6 during scanning.
I assumed hooking up the turntable via Bluetooth (which works fine btw), the software would control the tilt automatically during scanning. But nothing happens and the only thing I have found is that you can only manually control it remotely via the add-on menu.
Does Revoscan 6 support automatic remote control in the first place or is it only manual remote control?
Best regards.
when scanning you can select the connections before the scan to add the turntable connection and the angle
what part of the old turntable died? i had a motor die from my older turntable v1, and i replaced the motor myself to get it back up and running properly again. i now have my older turntable as a backup (put on reflective dots as it did not have reflective), and the turntable v2 that came with my MetroX.
I know, I got that far. My question was more, can the tilting be automised by the software? Example, after 3 turns the platform will titlt 15degrees, do 3 turns, and tilt all the way to minus 15degrees without user input.
To me it seems that the gear was stripped from some teeth. After one turn it will just stop turning until I move the platform a little bit with my finger until it engages. I still want to see if I can take it apart and examine what is broken and if it’s still fixable.
Here is a video showing the issue.
Please note that I already reached out to Revopoint and they provided great support by sending me a working replacement.
Edit: I opened it up and seems I was correct. So the obvious answer is to scan the inside and print a new gear lol.
