Big objects, small details, limits redefined
The wait is over. The RANGE 3 and RANGE 3 Pro have officially landed, redefining what’s possible in medium to large scale 3D scanning.
We’ve evolved the series into a more versatile powerhouse with new outdoor performance and extended capability for smaller objects. While both models dominate open-air scans, the RANGE 3 Pro adds a markerless laser scanning for ultimate convenience. From 3D printing to professional engineering, this is your new workflow essential.
Exclusive Savings:
Pre-order Special: 5% OFF
Extra Social Discount: Use code [MEDIARIFO2] for an additional 2% OFF
Grab yours now and elevate your workflow.
US store | Global store
I loved the Range 1. Will we ever see 1300mm working distance again?
Hi @TheBoatScans yes in the future …
BTW my Range 0 Beta can scan from 2000m distance , but the resolution of the scans is on the lowest side.
It was later reduced to Range 1 version you own.
The problem with distance are keeping the pattern small enough to be able to capture the proper accuracy .
For that the laser class power need to increase and making it less consumer friendly. Then you have other regulations etc..
But Revopoint never sleeps and working on new things at the same time so stay tuned.
Hi Filip,
I think you could profit here more from MIRACO 2 than Range 3
Range 3 can capture smaller objects too but I would keep it only for scanning 1-2m and Up objects.
anymore detail for markerless laser scan mode? :o im interested into this feature
head to head comparsion between all 3 gens of range scanner (feature Infrared scanning mode,.
also laser mode (detail of the scan) between range3 compare with metro series?
thanks
Hi @kkula9999
I will post my Range 3 showcase this week, stay tuned ..
Laser markerless function uses color tracking mode , in place of looking for geometry , it tracking by unique color pattern even if black and white.
More info and comparisons this week.
