Alternative turntable
Hello,
will the mini work well with any turntable or is there some kind of optimised scan angles programmed into the dual axis one? thanks
Hi, No the angles will depend on what part or item you are going to scan, The scanner works with line of sight as and eg. The turn table flat would work for spur gears but the multi axis turn table would be better suited for bevel gears. The angle would be determined ultimately of the object you want to scan.
You can use any turntable with MINI and all other devices .
However Dual Axis turntable allows you to capture the organic model all at once without the needs of flipping it on the sides .
